メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ElitePad 1000 G2 Display Replacement
必要な工具と部品
  1. HP ElitePad 1000 G2 Display Replacement, Display: 手順 1、 3の画像 1 HP ElitePad 1000 G2 Display Replacement, Display: 手順 1、 3の画像 2 HP ElitePad 1000 G2 Display Replacement, Display: 手順 1、 3の画像 3
    • Before disassembling the tablet: make sure the tablet is off, disconnect the power cord from the tablet, and disconnect all external devices from the tablet.
    • Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
    FixBotに聞いてみる
    コメントを追加
  2. HP ElitePad 1000 G2 Display Replacement: 手順 2、 3の画像 1 HP ElitePad 1000 G2 Display Replacement: 手順 2、 3の画像 2 HP ElitePad 1000 G2 Display Replacement: 手順 2、 3の画像 3
    • Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
    • Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
    • Pull on the suction cup while using the prying tool to separate the display from the tablet.
    • Gently lift the display from the tablet in order to avoid damaging the cables.
    FixBotに聞いてみる
    コメントを追加
  3. HP ElitePad 1000 G2 Display Replacement: 手順 3、 3の画像 1 HP ElitePad 1000 G2 Display Replacement: 手順 3、 3の画像 2 HP ElitePad 1000 G2 Display Replacement: 手順 3、 3の画像 3
    • To disconnect the cables, use the spudger tool to gently pull back on the black tab located on the side of the connector while gently pulling the cable.
    • Release the zero insertion force (ZIF) connector to which the TouchScreen cable is attached, and then disconnect the TouchScreen cable from the system board.
    FixBotに聞いてみる
    コメントを追加
  4. HP ElitePad 1000 G2 Display Replacement: 手順 4、 2の画像 1 HP ElitePad 1000 G2 Display Replacement: 手順 4、 2の画像 2
    • Release the ZIF connector to which the display cable is attached, and then disconnect the display cable from the system board.
    FixBotに聞いてみる
    コメントを追加
  5. HP ElitePad 1000 G2 Display Replacement: 手順 5、 2の画像 1 HP ElitePad 1000 G2 Display Replacement: 手順 5、 2の画像 2
    • Remove the display from the tablet.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Jonathan Beasey
メンバー登録日: 07/09/19
262 ポイント
2のガイドは作成済み
チーム
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 27
今までの合計 1,379
