メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HMD Fusion Screen Replacement
必要な工具と部品
  1. HMD Fusion Screen Replacement, Prepare your phone for disassembly: 手順 1、 1の画像 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    FixBotに聞いてみる
    コメントを追加
  2. HMD Fusion Screen Replacement, Remove the SIM card tray: 手順 2、 3の画像 1 HMD Fusion Screen Replacement, Remove the SIM card tray: 手順 2、 3の画像 2 HMD Fusion Screen Replacement, Remove the SIM card tray: 手順 2、 3の画像 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    FixBotに聞いてみる
    コメントを追加
  3. HMD Fusion Screen Replacement, Remove the back cover screws: 手順 3、 3の画像 1 HMD Fusion Screen Replacement, Remove the back cover screws: 手順 3、 3の画像 2 HMD Fusion Screen Replacement, Remove the back cover screws: 手順 3、 3の画像 3
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
    FixBotに聞いてみる
    コメントを追加
  4. HMD Fusion Screen Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $16.96
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
    FixBotに聞いてみる
    コメントを追加
  5. HMD Fusion Screen Replacement, Unclip the back cover: 手順 5、 2の画像 1 HMD Fusion Screen Replacement, Unclip the back cover: 手順 5、 2の画像 2
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
    FixBotに聞いてみる
    コメントを追加
  6. HMD Fusion Screen Replacement: 手順 6、 3の画像 1 HMD Fusion Screen Replacement: 手順 6、 3の画像 2 HMD Fusion Screen Replacement: 手順 6、 3の画像 3
    • Slide the opening pick along the left edge to begin unclipping the back cover.
    FixBotに聞いてみる
    コメントを追加
  7. HMD Fusion Screen Replacement: 手順 7、 3の画像 1 HMD Fusion Screen Replacement: 手順 7、 3の画像 2 HMD Fusion Screen Replacement: 手順 7、 3の画像 3
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
    FixBotに聞いてみる
    コメントを追加
  8. HMD Fusion Screen Replacement: 手順 8、 3の画像 1 HMD Fusion Screen Replacement: 手順 8、 3の画像 2 HMD Fusion Screen Replacement: 手順 8、 3の画像 3
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
    FixBotに聞いてみる
    コメントを追加
  9. HMD Fusion Screen Replacement, Disconnect the battery: 手順 9、 3の画像 1 HMD Fusion Screen Replacement, Disconnect the battery: 手順 9、 3の画像 2 HMD Fusion Screen Replacement, Disconnect the battery: 手順 9、 3の画像 3
    FixBotに聞いてみる
    コメントを追加
  10. HMD Fusion Screen Replacement, Disconnect the power button: 手順 10、 3の画像 1 HMD Fusion Screen Replacement, Disconnect the power button: 手順 10、 3の画像 2 HMD Fusion Screen Replacement, Disconnect the power button: 手順 10、 3の画像 3
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
    FixBotに聞いてみる
    コメントを追加
  11. HMD Fusion Screen Replacement, Screen: 手順 11、 3の画像 1 HMD Fusion Screen Replacement, Screen: 手順 11、 3の画像 2 HMD Fusion Screen Replacement, Screen: 手順 11、 3の画像 3
    • For the next step, you'll need to hold the graphite sheet out of the way of the display connector along the bottom of the motherboard.
    • Alternatively, you can use tape with light adhesive (such as painter's tape) to keep the graphite sheet out of the way.
    FixBotに聞いてみる
    コメントを追加
  12. HMD Fusion Screen Replacement, Disconnect the display: 手順 12、 2の画像 1 HMD Fusion Screen Replacement, Disconnect the display: 手順 12、 2の画像 2
    • Use a spudger to pry up and disconnect the display press connector.
    • Pry under the right edge of the connector, as there are delicate surface‑mounted components to the left of it.
    FixBotに聞いてみる
    コメントを追加
  13. HMD Fusion Screen Replacement, Separate the front camera: 手順 13、 2の画像 1 HMD Fusion Screen Replacement, Separate the front camera: 手順 13、 2の画像 2
    • Use the tip of a spudger to pry up the front camera from the frame and separate its adhesive.
    FixBotに聞いてみる
    コメントを追加
  14. HMD Fusion Screen Replacement, Remove the screen screws: 手順 14、 2の画像 1 HMD Fusion Screen Replacement, Remove the screen screws: 手順 14、 2の画像 2
    • Use a T3 Torx screwdriver to remove the seven 3.3 mm‑long screws securing the screen:
    • Five screws on the motherboard
    • Two screws on the loudspeaker
    • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
    FixBotに聞いてみる
    コメントを追加
  15. HMD Fusion Screen Replacement, Remove the screen: 手順 15、 2の画像 1 HMD Fusion Screen Replacement, Remove the screen: 手順 15、 2の画像 2
    • Lift the screen off the frame, making sure to thread the display cable through its slot.
    • Remove the screen.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
239,519 ポイント
1,171のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
25,948のガイドは作成済み
5件のガイドコメント
Wo kann ich ein Ersatzdisplay bestellen? (Bin aus der Schweiz)
Ivan Haedo - 返信 共有
Will the parts ever be in stock in Europe? Pointless to buy a repairable phone when you can't buy the parts
Ejrj - 返信 共有
In teh description you remove the screen, but Ifix send a sreen with a frame fixed to it. no way this is gona fit.
L Verheul - 返信 共有
Yes, the new screen has a frame attached to it. Just remove every screw on it an detach the frame carefully. I guess the frame supports the screen for transportation.
Robert Reiter - 返信 共有
Hello, I am in Portugal, can I buy the screen on this website?
Sand.barack - 返信 共有
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 97
過去 30 日: 394
今までの合計 7,581
