メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin Vivoactive Display Unit Replacement
必要な工具と部品
    1. Garmin Vivoactive Display Unit Replacement, Wristband: 手順 1、 1の画像 1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Vivoactive Display Unit Replacement: 手順 2、 2の画像 1 Garmin Vivoactive Display Unit Replacement: 手順 2、 2の画像 2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: 手順 3、 1の画像 1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Vivoactive Display Unit Replacement: 手順 4、 2の画像 1 Garmin Vivoactive Display Unit Replacement: 手順 4、 2の画像 2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin Vivoactive Display Unit Replacement: 手順 5、 1の画像 1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin Vivoactive Display Unit Replacement: 手順 6、 1の画像 1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      FixBotに聞いてみる
      コメントを追加
    5. Garmin Vivoactive Display Unit Replacement: 手順 7、 1の画像 1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    6. Garmin Vivoactive Display Unit Replacement: 手順 8、 1の画像 1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
16 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Katie Paswaters
メンバー登録日: 10/01/15
532 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S1G21
4 メンバー
17のガイドは作成済み
40件のガイドコメント
Does anyone knows where can I buy a vivoactive display?
dragomariano - 返信 共有
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - 返信 共有
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - 返信 共有
Any links found for replacement screen?
dskggray - 返信 共有
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 134
今までの合計 105,325
