メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin Vívoactive 4 Screen Replacement
必要な工具と部品
    1. Garmin Vívoactive 4 Screen Replacement, Watch Band: 手順 1、 1の画像 1
      • Flip the watch on its back to reveal the watch band connection pins.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Vívoactive 4 Screen Replacement, Remove Bands: 手順 2、 3の画像 1 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 手順 2、 3の画像 2 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 手順 2、 3の画像 3
      • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
      • Push on the pin to release the strap from it's hinge.
      • Pull the strap away from the watch to disconnect it.
      • The strap will not pull away if the pin isn't fully pushed in.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin Vívoactive 4 Screen Replacement: 手順 3、 1の画像 1
      • With both straps removed, a new replacement watch band may be inserted.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Vívoactive 4 Screen Replacement, Screen: 手順 4、 1の画像 1
      • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
      • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Vívoactive 4 Screen Replacement: 手順 5、 2の画像 1 Garmin Vívoactive 4 Screen Replacement: 手順 5、 2の画像 2
      • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
      • Pry the screen off the device.
      • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
      • Work quickly so the adhesive doesn’t cool too much.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin Vívoactive 4 Screen Replacement: 手順 6、 3の画像 1 Garmin Vívoactive 4 Screen Replacement: 手順 6、 3の画像 2 Garmin Vívoactive 4 Screen Replacement: 手順 6、 3の画像 3
      • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin Vívoactive 4 Screen Replacement: 手順 7、 1の画像 1
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jacob Byron
メンバー登録日: 11/01/23
223 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023人のメンバー
UMASSD-PETERSEN-F23S1G3
4 メンバー
16のガイドは作成済み
3件のガイドコメント
Will this affect the waterproofing of the device?
Interested Repairer - 返信 共有
I originally had this watch not responding to touch (it was gradual, parts of the screen started not working bit by bit). Finally the whole screen did not respond to touch inputs. Suspected the entire screen assembly had to be replaced but this shockingly proved unsuccessful. What else would kill this capability of the watch? I don't understand!
Shaun Tam - 返信 共有
wait, I got the screen to work after a hard restart. Quite interesting, it must be learning/recalibrating the inputs each time it starts, like a scale.
My watch now crashes and turns off whenever I try to start an activity (I tried the run activity) and when trying to do NFC payments. The screen was the only thing I played with. What could cause this? I remember hearing from someone that the bezel acts as an antenna of sorts.
Shaun Tam - 返信 共有
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 60
過去 30 日: 225
今までの合計 6,422
