メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin DriveSmart 55 EX Screen Replacement
必要な工具と部品
    1. Garmin DriveSmart 55 EX Screen Replacement, Screen: 手順 1、 3の画像 1 Garmin DriveSmart 55 EX Screen Replacement, Screen: 手順 1、 3の画像 2 Garmin DriveSmart 55 EX Screen Replacement, Screen: 手順 1、 3の画像 3
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin DriveSmart 55 EX Screen Replacement: 手順 2、 3の画像 1 Garmin DriveSmart 55 EX Screen Replacement: 手順 2、 3の画像 2 Garmin DriveSmart 55 EX Screen Replacement: 手順 2、 3の画像 3
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin DriveSmart 55 EX Screen Replacement: 手順 3、 2の画像 1 Garmin DriveSmart 55 EX Screen Replacement: 手順 3、 2の画像 2
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin DriveSmart 55 EX Screen Replacement: 手順 4、 3の画像 1 Garmin DriveSmart 55 EX Screen Replacement: 手順 4、 3の画像 2 Garmin DriveSmart 55 EX Screen Replacement: 手順 4、 3の画像 3
      • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
      • Be careful when removing the ribbon cable because it is thin and can tear easily.
      FixBotに聞いてみる
      コメントを追加
    5. Garmin DriveSmart 55 EX Screen Replacement: 手順 5、 2の画像 1 Garmin DriveSmart 55 EX Screen Replacement: 手順 5、 2の画像 2
      • Insert a spudger or plastic opening tool into the gap between the screen and display frame.
      • Once a corner begins to lift, slowly slide the tool around the edges to release the clips securing them.
      • The screen is glass and if you use too much force it can shatter and crack the screen.
      • Separate the screen from the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Jacob Behnke
メンバー登録日: 03/11/26
707 ポイント
4のガイドは作成済み
チーム
Purdue University Northwest, Team 7-1, Dieterle Spring 2026 Purdue University Northwest, Team 7-1, Dieterle Spring 2026人のメンバー
PNW-DIETERLE-S26S7G1
3 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 31
今までの合計 128
