メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin DriveSmart 55 EX Battery Replacement
必要な工具と部品
  1. Garmin DriveSmart 55 EX Battery Replacement, Battery: 手順 1、 3の画像 1 Garmin DriveSmart 55 EX Battery Replacement, Battery: 手順 1、 3の画像 2 Garmin DriveSmart 55 EX Battery Replacement, Battery: 手順 1、 3の画像 3
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    FixBotに聞いてみる
    コメントを追加
  2. Garmin DriveSmart 55 EX Battery Replacement: 手順 2、 3の画像 1 Garmin DriveSmart 55 EX Battery Replacement: 手順 2、 3の画像 2 Garmin DriveSmart 55 EX Battery Replacement: 手順 2、 3の画像 3
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  3. Garmin DriveSmart 55 EX Battery Replacement: 手順 3、 3の画像 1 Garmin DriveSmart 55 EX Battery Replacement: 手順 3、 3の画像 2 Garmin DriveSmart 55 EX Battery Replacement: 手順 3、 3の画像 3
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    • Gently remove the battery from the casing.
    • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
    • Avoid bending or puncturing the battery as it can catch fire.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Jacob Behnke
メンバー登録日: 03/11/26
707 ポイント
4のガイドは作成済み
チーム
Purdue University Northwest, Team 7-1, Dieterle Spring 2026 Purdue University Northwest, Team 7-1, Dieterle Spring 2026人のメンバー
PNW-DIETERLE-S26S7G1
3 メンバー
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 41
今までの合計 176
