メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Framework Laptop 13 Pro Wi-Fi Module Replacement
必要な工具と部品
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Before you begin: 手順 1、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Before you begin: 手順 1、 2の画像 2
      • Unplug all cables and fully shut down your laptop from the OS.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Loosen the Input Cover screws: 手順 2、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Loosen the Input Cover screws: 手順 2、 2の画像 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      FixBotに聞いてみる
      コメントを追加
    2. Framework Laptop 13 Pro Wi-Fi Module Replacement, Lift the Input Cover: 手順 3、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Lift the Input Cover: 手順 3、 2の画像 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      FixBotに聞いてみる
      コメントを追加
    3. Framework Laptop 13 Pro Wi-Fi Module Replacement, Flip over the Input Cover: 手順 4、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Flip over the Input Cover: 手順 4、 2の画像 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      FixBotに聞いてみる
      コメントを追加
    4. Framework Laptop 13 Pro Wi-Fi Module Replacement, Disconnect the Touchpad Cable: 手順 5、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Disconnect the Touchpad Cable: 手順 5、 2の画像 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      FixBotに聞いてみる
      コメントを追加
    5. Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Input Cover: 手順 6、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Input Cover: 手順 6、 2の画像 2
      • Remove the Input Cover.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: 手順 7、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Loosen the Wi-Fi module screw: 手順 7、 2の画像 2
      • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Wi-Fi module.
      • The module might pop up at a shallow angle when you loosen the screw.
      FixBotに聞いてみる
      コメントを追加
    2. Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Wi-Fi module cover: 手順 8、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Wi-Fi module cover: 手順 8、 2の画像 2
      • Slide the clear plastic cover straight off the module and remove it.
      FixBotに聞いてみる
      コメントを追加
    3. Framework Laptop 13 Pro Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 手順 9、 3の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 手順 9、 3の画像 2 Framework Laptop 13 Pro Wi-Fi Module Replacement, Disconnect the Wi-Fi module: 手順 9、 3の画像 3
      • While holding the Wi-Fi module down, insert the flat end of your Framework Screwdriver under one of the coaxial connectors, where the cable meets the metal head.
      • Lift the screwdriver straight up to disconnect the coaxial cable.
      • Repeat for the other coaxial cable.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Wi-Fi module: 手順 10、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Remove the Wi-Fi module: 手順 10、 2の画像 2
      • Grip the end of the Wi-Fi module with the screw hole and slide it out of its socket.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Disassembly complete: 手順 11、 1の画像 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Insert the Wi-Fi module: 手順 12、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Insert the Wi-Fi module: 手順 12、 2の画像 2
      • Grip the end of the Wi-Fi module with the screw hole and slide it straight into its socket.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Reconnect the Wi-Fi module: 手順 13、 3の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Reconnect the Wi-Fi module: 手順 13、 3の画像 2 Framework Laptop 13 Pro Wi-Fi Module Replacement, Reconnect the Wi-Fi module: 手順 13、 3の画像 3
      • Hold the Wi-Fi module down with your finger.
      • Position the black antenna cable connector over the Wi-Fi module's coaxial socket labeled by the black arrow.
      • If you're unsure which cable goes where, refer to the arrows on the Wi-Fi module for which color cable matches with its connector.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      FixBotに聞いてみる
      コメントを追加
    2. Framework Laptop 13 Pro Wi-Fi Module Replacement: 手順 14、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement: 手順 14、 2の画像 2
      • Slide the clear plastic cover onto the module and align its screw with the screw hole cutout.
      FixBotに聞いてみる
      コメントを追加
    3. Framework Laptop 13 Pro Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: 手順 15、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Tighten the Wi-Fi module screw: 手順 15、 2の画像 2
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw securing the Wi-Fi module.
      FixBotに聞いてみる
      コメントを追加
    1. Framework Laptop 13 Pro Wi-Fi Module Replacement, Position the Input Cover: 手順 16、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Position the Input Cover: 手順 16、 2の画像 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      FixBotに聞いてみる
      コメントを追加
    2. Framework Laptop 13 Pro Wi-Fi Module Replacement, Connect the Touchpad Cable: 手順 17、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Connect the Touchpad Cable: 手順 17、 2の画像 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
      FixBotに聞いてみる
      コメントを追加
    3. Framework Laptop 13 Pro Wi-Fi Module Replacement, Place the Input Cover: 手順 18、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Place the Input Cover: 手順 18、 2の画像 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      FixBotに聞いてみる
      コメントを追加
    4. Framework Laptop 13 Pro Wi-Fi Module Replacement: 手順 19、 3の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement: 手順 19、 3の画像 2 Framework Laptop 13 Pro Wi-Fi Module Replacement: 手順 19、 3の画像 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      FixBotに聞いてみる
      コメントを追加
    5. Framework Laptop 13 Pro Wi-Fi Module Replacement, Reposition the laptop: 手順 20、 1の画像 1
      • Close the laptop and flip it over.
      FixBotに聞いてみる
      コメントを追加
    6. Framework Laptop 13 Pro Wi-Fi Module Replacement, Tighten the Input Cover screws: 手順 21、 2の画像 1 Framework Laptop 13 Pro Wi-Fi Module Replacement, Tighten the Input Cover screws: 手順 21、 2の画像 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      FixBotに聞いてみる
      コメントを追加
終わりに
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
キャンセル: このガイドを終了できませんでした。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
249,889 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 28
過去 30 日: 80
今までの合計 204
