メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Framework Laptop 12 Fastener Guide
必要な工具と部品
  1. Framework Laptop 12 Fastener Guide, Fasteners information: 手順 1、 2の画像 1 Framework Laptop 12 Fastener Guide, Fasteners information: 手順 1、 2の画像 2
    • The Fastener Kit contains the following:
    • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
    • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
    • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
    • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
    • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
    FixBotに聞いてみる
    コメントを追加
  2. Framework Laptop 12 Fastener Guide, Antenna screws: 手順 2、 3の画像 1 Framework Laptop 12 Fastener Guide, Antenna screws: 手順 2、 3の画像 2 Framework Laptop 12 Fastener Guide, Antenna screws: 手順 2、 3の画像 3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
    FixBotに聞いてみる
    コメントを追加
  3. Framework Laptop 12 Fastener Guide, Display screws: 手順 3、 2の画像 1 Framework Laptop 12 Fastener Guide, Display screws: 手順 3、 2の画像 2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
    FixBotに聞いてみる
    コメントを追加
  4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 手順 4、 3の画像 1 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 手順 4、 3の画像 2 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: 手順 4、 3の画像 3
    • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
    • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
    FixBotに聞いてみる
    コメントを追加
  5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 手順 5、 3の画像 1 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 手順 5、 3の画像 2 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): 手順 5、 3の画像 3
    • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
    FixBotに聞いてみる
    コメントを追加
  6. Framework Laptop 12 Fastener Guide, Hinge screws (top): 手順 6、 3の画像 1 Framework Laptop 12 Fastener Guide, Hinge screws (top): 手順 6、 3の画像 2 Framework Laptop 12 Fastener Guide, Hinge screws (top): 手順 6、 3の画像 3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
    FixBotに聞いてみる
    コメントを追加
  7. Framework Laptop 12 Fastener Guide, Power Button screw: 手順 7、 2の画像 1 Framework Laptop 12 Fastener Guide, Power Button screw: 手順 7、 2の画像 2
    • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
    FixBotに聞いてみる
    コメントを追加
  8. Framework Laptop 12 Fastener Guide, SSD clip screw: 手順 8、 2の画像 1 Framework Laptop 12 Fastener Guide, SSD clip screw: 手順 8、 2の画像 2
    • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
    FixBotに聞いてみる
    コメントを追加
  9. Framework Laptop 12 Fastener Guide, Touchpad screws: 手順 9、 3の画像 1 Framework Laptop 12 Fastener Guide, Touchpad screws: 手順 9、 3の画像 2 Framework Laptop 12 Fastener Guide, Touchpad screws: 手順 9、 3の画像 3
    • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
    FixBotに聞いてみる
    コメントを追加
  10. Framework Laptop 12 Fastener Guide, Webcam screws: 手順 10、 2の画像 1 Framework Laptop 12 Fastener Guide, Webcam screws: 手順 10、 2の画像 2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
    FixBotに聞いてみる
    コメントを追加
終わりに
If you need help, contact Framework support.
キャンセル: このガイドを終了できませんでした。
Arthur Shi
メンバー登録日: 01/03/18
337,991 ポイント
851のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 40
今までの合計 249
