メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dirt Devil Gator Battery Replacement
必要な工具と部品
  1. Dirt Devil Gator Battery Replacement, Battery: 手順 1、 1の画像 1
    • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
    FixBotに聞いてみる
    コメントを追加
  2. Dirt Devil Gator Battery Replacement: 手順 2、 3の画像 1 Dirt Devil Gator Battery Replacement: 手順 2、 3の画像 2 Dirt Devil Gator Battery Replacement: 手順 2、 3の画像 3
    • Separate the vacuum by pulling on the back of the vacuum. There should not be heavy resistance when pulling.
    FixBotに聞いてみる
    コメントを追加
  3. Dirt Devil Gator Battery Replacement: 手順 3、 3の画像 1 Dirt Devil Gator Battery Replacement: 手順 3、 3の画像 2 Dirt Devil Gator Battery Replacement: 手順 3、 3の画像 3
    • Unscrew each of the 13 mm screws with the micro screwdriver from the vacuum.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
    FixBotに聞いてみる
    コメントを追加
  4. Dirt Devil Gator Battery Replacement: 手順 4、 3の画像 1 Dirt Devil Gator Battery Replacement: 手順 4、 3の画像 2 Dirt Devil Gator Battery Replacement: 手順 4、 3の画像 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
    FixBotに聞いてみる
    コメントを追加
  5. Dirt Devil Gator Battery Replacement: 手順 5、 2の画像 1 Dirt Devil Gator Battery Replacement: 手順 5、 2の画像 2
    • Cut the white and black wires with wire cutters to disconnect battery from the motor. Follow this guide to desolder!
    • Remove the tan couplings from their white sockets and replace with new batteries.
    • If the battery is torn or has battery acid around it, do not touch the battery. Safely dispose the battery. If come into contact with acid, wash hands thoroughly.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. The battery is not likely to fail, but if it does when following these steps, you will see something immediately wrong.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Ryan Marando
メンバー登録日: 01/24/20
703 ポイント
5のガイドは作成済み
チーム
3件のガイドコメント
So, where can I purchase a battery replacement?
ed1660wmh - 返信 共有
You neglected to mention one VITAL item, what is the part number for the replacement batteries or where does one find those? I've searched all over the internet and cannot find them anywhere. The company says they are NOT user serviceable or replaceable parts. For me, it's not a matter of being able to the job, I definitely can, but it is not possible without the parts.
Vince Pepple - 返信 共有
Judging by the pictures, the battery seems to be comprised of standard sub-c NiCd cells.
You would probably also be able to use NiMh cells, which would grant you a little more runtime and can be bought pretty much everywhere.
RobinKemen - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 20
過去 30 日: 75
今までの合計 8,792
