メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Core Assembly Removal
必要な工具と部品
  1. Core Assembly Removal, Power down your watch: 手順 1、 2の画像 1 Core Assembly Removal, Power down your watch: 手順 1、 2の画像 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    FixBotに聞いてみる
    コメントを追加
  2. Core Assembly Removal, Unfasten the back cover: 手順 2、 1の画像 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    FixBotに聞いてみる
    コメントを追加
  3. Core Assembly Removal, Loosen the back cover adhesive: 手順 3、 1の画像 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    FixBotに聞いてみる
    コメントを追加
  4. Core Assembly Removal, Pry up the back cover assembly: 手順 4、 3の画像 1 Core Assembly Removal, Pry up the back cover assembly: 手順 4、 3の画像 2 Core Assembly Removal, Pry up the back cover assembly: 手順 4、 3の画像 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    FixBotに聞いてみる
    コメントを追加
  5. Core Assembly Removal, Disconnect the sensor assembly cable: 手順 5、 2の画像 1 Core Assembly Removal, Disconnect the sensor assembly cable: 手順 5、 2の画像 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    FixBotに聞いてみる
    コメントを追加
  6. Core Assembly Removal, Remove the back cover assembly: 手順 6、 3の画像 1 Core Assembly Removal, Remove the back cover assembly: 手順 6、 3の画像 2 Core Assembly Removal, Remove the back cover assembly: 手順 6、 3の画像 3
    • Remove the back cover assembly.
    FixBotに聞いてみる
    コメントを追加
  7. Core Assembly Removal, Disconnect the microphone cable: 手順 7、 2の画像 1 Core Assembly Removal, Disconnect the microphone cable: 手順 7、 2の画像 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
    FixBotに聞いてみる
    コメントを追加
  8. Core Assembly Removal, Unfasten the core assembly: 手順 8、 1の画像 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
    FixBotに聞いてみる
    コメントを追加
  9. Core Assembly Removal, Pry up the core assembly: 手順 9、 2の画像 1 Core Assembly Removal, Pry up the core assembly: 手順 9、 2の画像 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
    FixBotに聞いてみる
    コメントを追加
  10. Core Assembly Removal, Swing open the core assembly: 手順 10、 3の画像 1 Core Assembly Removal, Swing open the core assembly: 手順 10、 3の画像 2 Core Assembly Removal, Swing open the core assembly: 手順 10、 3の画像 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
    FixBotに聞いてみる
    コメントを追加
  11. Core Assembly Removal, Disconnect the display cables: 手順 11、 3の画像 1 Core Assembly Removal, Disconnect the display cables: 手順 11、 3の画像 2 Core Assembly Removal, Disconnect the display cables: 手順 11、 3の画像 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
    FixBotに聞いてみる
    コメントを追加
  12. Core Assembly Removal, Remove the core assembly: 手順 12、 2の画像 1 Core Assembly Removal, Remove the core assembly: 手順 12、 2の画像 2
    • Remove the core assembly.
    FixBotに聞いてみる
    コメントを追加
終わりに
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
260,519 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
122 メンバー
27,491のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 42
今までの合計 1,510
