メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Chef's Choice M115 Motor Assembly Replacement
必要な工具と部品
    1. Chef's Choice M115 Motor Assembly Replacement, Case: 手順 1、 2の画像 1 Chef's Choice M115 Motor Assembly Replacement, Case: 手順 1、 2の画像 2
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      FixBotに聞いてみる
      コメントを追加
    2. Chef's Choice M115 Motor Assembly Replacement: 手順 2、 1の画像 1
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      FixBotに聞いてみる
      コメントを追加
    3. Chef's Choice M115 Motor Assembly Replacement: 手順 3、 1の画像 1
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      FixBotに聞いてみる
      コメントを追加
    4. Chef's Choice M115 Motor Assembly Replacement: 手順 4、 1の画像 1
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      FixBotに聞いてみる
      コメントを追加
    1. Chef's Choice M115 Motor Assembly Replacement, Power Cord: 手順 5、 2の画像 1 Chef's Choice M115 Motor Assembly Replacement, Power Cord: 手順 5、 2の画像 2
      • Carefully lift the entire motor assembly out of the case.
      FixBotに聞いてみる
      コメントを追加
    2. Chef's Choice M115 Motor Assembly Replacement: 手順 6、 1の画像 1
      • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
      • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
      FixBotに聞いてみる
      コメントを追加
    3. Chef's Choice M115 Motor Assembly Replacement: 手順 7、 1の画像 1
      • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
      FixBotに聞いてみる
      コメントを追加
    1. Chef's Choice M115 Motor Assembly Replacement, Motor Assembly: 手順 8、 1の画像 1
      • Reconnect the wires of the new motor assembly with the power cord and reassemble the device.
      • If your replacement motor assembly does not come with grinding discs or linkage pins, refer to our guides below:
      • Grinding Discs Guide
      • Linkage Pins Guide
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Zachary Grounds
メンバー登録日: 09/17/15
592 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015人のメンバー
IUPUI-HARLEY-F15S3G3
5 メンバー
14のガイドは作成済み
2件のガイドコメント
Any idea what might be wrong when ... stones don't spin, but you can hear the motor is turned on? Sounds like what would happen if something was jammed and the shaft won't turn BUT I've checked and the disks spin freely when the motor is off. I'm not sure it's worth messing with unless someone can tell me what to check.
Dan M - 返信 共有
I’m having the same problem! I’m guessing that this problem (of the motor turning on but not spinning the wheels) is in fact the motor not working. Obviously this is an old comment, but if anyone else knows if this is true, please let me know.
Gretchen Ela - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 37
今までの合計 2,172
