はじめに
If the sharpening stones become loose or do not apply the correct pressure to the knifes, this could be caused by either broken or missing linkage pins. These pins hold the sharpening stones in place on the motor axle. Replacing a broken or missing pin is a relatively easy process.
必要な工具と部品
Remove the motor and shaft assembly from the bottom of the case housing.
ある他の人がこのガイドを完成しました。
コメント 1 件
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - 返信
