メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Blink Outdoor 4 Camera Replacement
必要な工具と部品
  1. Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 手順 1、 3の画像 1 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 手順 1、 3の画像 2 Blink Outdoor 4 Camera Replacement, Blink Outdoor 4 Camera: 手順 1、 3の画像 3
    • Remove the mounting bracket from the device if necessary.
    • Flip the camera upside down.
    • The word 'Blink' should be at the top.
    • Insert the swivel multi-tool that was included in the Blink Outdoor 4 box into the small notch located inside the silver circle in the center of the device.
    • Twist to the left until you hear a click.
    FixBotに聞いてみる
    コメントを追加
  2. Blink Outdoor 4 Camera Replacement: 手順 2、 2の画像 1 Blink Outdoor 4 Camera Replacement: 手順 2、 2の画像 2
    • Use a spudger to gently pry the back casing off the device.
    • Remove the two batteries and set them aside.
    • When reattaching the back casing, turn the swivel tool to the right.
    FixBotに聞いてみる
    コメントを追加
  3. Blink Outdoor 4 Camera Replacement: 手順 3、 2の画像 1 Blink Outdoor 4 Camera Replacement: 手順 3、 2の画像 2
    • Remove all four screws near the battery compartments using a Phillips #1 screwdriver.
    • Make sure to keep track of the screws for reassembly.
    FixBotに聞いてみる
    コメントを追加
  4. Blink Outdoor 4 Camera Replacement: 手順 4、 3の画像 1 Blink Outdoor 4 Camera Replacement: 手順 4、 3の画像 2 Blink Outdoor 4 Camera Replacement: 手順 4、 3の画像 3
    • Turn the device on its side.
    • Use a plastic spudger to gently pry off the front cover of the device.
    FixBotに聞いてみる
    コメントを追加
  5. Blink Outdoor 4 Camera Replacement: 手順 5、 3の画像 1 Blink Outdoor 4 Camera Replacement: 手順 5、 3の画像 2 Blink Outdoor 4 Camera Replacement: 手順 5、 3の画像 3
    • Use a Phillips #00 screwdriver to remove the two small black screws in the upper right corner of the board.
    • Make sure to keep the screws for reassembly.
    • Gently lift the motherboard out of the device by its edges.
    • Do not pull on the board because it's attached to some cables from underneath and it could damage the device.
    FixBotに聞いてみる
    コメントを追加
  6. Blink Outdoor 4 Camera Replacement: 手順 6、 3の画像 1 Blink Outdoor 4 Camera Replacement: 手順 6、 3の画像 2 Blink Outdoor 4 Camera Replacement: 手順 6、 3の画像 3
    • Squeeze the edges of the white camera connector and slide it out of the socket on the motherboard.
    • If that doesn't work, use the point of a spudger to push on alternating sides of the white camera connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • Remove the camera from the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Delaney Hye
メンバー登録日: 02/05/26
749 ポイント
5のガイドは作成済み
チーム
Texas Tech, Team 11-5, Weston Spring 2026 Texas Tech, Team 11-5, Weston Spring 2026人のメンバー
TTU-WESTON-S26S11G5
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 32
過去 30 日: 128
今までの合計 333
