メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Studio 2 Wireless Bluetooth Board Replacement
必要な工具と部品
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 手順 1、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: 手順 1、 2の画像 2
      • Insert a spudger between the plastic part of the left headphone and the ear cushion.
      • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
      FixBotに聞いてみる
      コメントを追加
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 2、 3の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 2、 3の画像 2 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 2、 3の画像 3
      • Pull the rest of the cushion away from the adhesive with your hands.
      FixBotに聞いてみる
      コメントを追加
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 手順 3、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: 手順 3、 2の画像 2
      • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
      • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
      FixBotに聞いてみる
      コメントを追加
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 4、 1の画像 1
      • Gently separate the speaker from the headphones.
      • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
      FixBotに聞いてみる
      コメントを追加
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 5、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 5、 2の画像 2
      • Gently pull the wire with rubber connectors off of the speaker.
      FixBotに聞いてみる
      コメントを追加
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 6、 1の画像 1
      • Use a soldering iron to desolder the two connections.
      • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
      • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
      • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
      FixBotに聞いてみる
      コメントを追加
    1. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: 手順 7、 1の画像 1
      • Peel off the sticker underneath the speaker.
      FixBotに聞いてみる
      コメントを追加
    2. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 8、 1の画像 1
      • Remove the center screw using a Phillips #00 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    3. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 9、 1の画像 1
      • Separate the plastic case from the rubber backing by hand or with a spudger.
      FixBotに聞いてみる
      コメントを追加
    4. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 10、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 10、 2の画像 2
      • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
      FixBotに聞いてみる
      コメントを追加
    5. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 11、 1の画像 1
      • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
      • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
      FixBotに聞いてみる
      コメントを追加
    6. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 12、 1の画像 1
      • Slide the front case down to separate it from the back and reveal the Bluetooth board.
      FixBotに聞いてみる
      コメントを追加
    7. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 13、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 13、 2の画像 2
      • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
      • This will free the Bluetooth board from the back case.
      FixBotに聞いてみる
      コメントを追加
    8. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 14、 2の画像 1 Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 14、 2の画像 2
      • Remove the Bluetooth board from the case.
      • Remove the translucent sticker from the back of the Bluetooth board.
      FixBotに聞いてみる
      コメントを追加
    9. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 15、 1の画像 1
      • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
      FixBotに聞いてみる
      コメントを追加
    10. Beats Studio 2 Wireless Bluetooth Board Replacement: 手順 16、 1の画像 1
      • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
      • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
      • The soldering iron can reach very high temperatures. Use it with caution.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jack Wilson
メンバー登録日: 03/20/23
599 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023人のメンバー
UMASSD-RAMOS-S23S5G3
3 メンバー
16のガイドは作成済み
1件のガイドコメント
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 57
今までの合計 2,947
