メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Anker Soundcore Space One Microphone Replacement
必要な工具と部品
    1. Anker Soundcore Space One Microphone Replacement, Ear Pads: 手順 1、 1の画像 1
      • Flip over the device so the ear pads face up.
      • This replacement guide will only cover one of the ear pads. The same exact steps apply to both.
      FixBotに聞いてみる
      コメントを追加
    2. Anker Soundcore Space One Microphone Replacement: 手順 2、 2の画像 1 Anker Soundcore Space One Microphone Replacement: 手順 2、 2の画像 2
      • Insert a spudger (plastic or metal) between the ear pad and the driver housing (the driver housing is the outside plastic part of ear cup).
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one.
      • Pry around the ear pad in a circular path until it fully releases.
      FixBotに聞いてみる
      コメントを追加
    3. Anker Soundcore Space One Microphone Replacement: 手順 3、 1の画像 1
      • Remove the ear pad from the driver housing.
      • The gray foam component shown is an additional protective component of the ear pad. You can remove it with your hands if needed, without any tools.
      FixBotに聞いてみる
      コメントを追加
    1. Anker Soundcore Space One Microphone Replacement, Driver: 手順 4、 2の画像 1 Anker Soundcore Space One Microphone Replacement, Driver: 手順 4、 2の画像 2
      • Position the inside of the driver housing facing up (without the ear pad).
      • Unscrew the six 6.1 mm Phillips #00 screws from the driver housing.
      FixBotに聞いてみる
      コメントを追加
    2. Anker Soundcore Space One Microphone Replacement: 手順 5、 2の画像 1 Anker Soundcore Space One Microphone Replacement: 手順 5、 2の画像 2
      • Pry around the interior plate of the driver housing with a spudger.
      • Carefully lift out the interior plate of the driver housing with a spudger to fully remove it.
      • This component has wires still connected to it, so don't be too aggressive when popping it off.
      FixBotに聞いてみる
      コメントを追加
    3. Anker Soundcore Space One Microphone Replacement: 手順 6、 2の画像 1 Anker Soundcore Space One Microphone Replacement: 手順 6、 2の画像 2
      • Flip the popped-off plate component away from the ear cup.
      • Use a soldering iron in a circular path along with the seam of the glue (white lining) to separate the two components that are glued together.
      • The soldering iron is extremely hot and could burn the user if used incorrectly. Please proceed with caution.
      • Pop off this component once it has detached from the glue (a spudger may be needed for this).
      FixBotに聞いてみる
      コメントを追加
    4. Anker Soundcore Space One Microphone Replacement: 手順 7、 2の画像 1 Anker Soundcore Space One Microphone Replacement: 手順 7、 2の画像 2
      • Pry the white adhesive layer around the driver component off with a spudger.
      • The actual driver is the metal disc in the center. The entire driver component includes everything inside the white lining (pictured in the second image).
      FixBotに聞いてみる
      コメントを追加
    5. Anker Soundcore Space One Microphone Replacement: 手順 8、 2の画像 1 Anker Soundcore Space One Microphone Replacement: 手順 8、 2の画像 2
      • Insert a Phillips #00 screwdriver into the hole in the metal center of the actual driver.
      • Pop off the driver component.
      • You will have to replace the entire driver component pictured, since there's no given way to retrieve the actual driver. If you attempt to replace just the actual driver, it could risk damaging interior components.
      FixBotに聞いてみる
      コメントを追加
    1. Anker Soundcore Space One Microphone Replacement, Microphone: 手順 9、 1の画像 1
      • Locate the microphones by looking in the outside bowl area fit with wires and white spots.
      • This guide covers the microphones in the left ear cup. There's one other microphone in the right ear cup.
      FixBotに聞いてみる
      コメントを追加
    2. Anker Soundcore Space One Microphone Replacement: 手順 10、 1の画像 1
      • Remove the microphones from underneath the white coverings with a spudger.
      FixBotに聞いてみる
      コメントを追加
    3. Anker Soundcore Space One Microphone Replacement: 手順 11、 1の画像 1
      • Pop out the microphones from underneath their white coverings.
      • The same process is done to the other two microphones
      FixBotに聞いてみる
      コメントを追加
終わりに
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
5人の作成者と共同で作成されました。
Malcolm Hewlett
メンバー登録日: 03/21/25
433 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025人のメンバー
UMASSD-BOTVIN-S25S2G3
3 メンバー
19のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 69
今までの合計 742
