はじめに
Throughout your continued use of your speaker’s lifespan, you may notice it not lasting quite as long as it used to, overheating with minimal use, or just not working at all. This may indicate the need for a battery replacement. This guide will demonstrate the proper procedures for replacing your Anker Soundcore Boost A3145’s battery. It is important to note that your device should be fully powered off and unplugged before proceeding with the repair.
必要な工具と部品
Remove the eight 9 mm Phillips #0 screws from around the base plate.
Remove the six 6.3 mm Phillips #0 screws from around the battery cap.
Use a spudger to pry up the base plate.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
ある他の人がこのガイドを完成しました。
