メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Kindle 8 Battery Replacement
必要な工具と部品
    1. Amazon Kindle 8 Battery Replacement, Front Cover: 手順 1、 2の画像 1 Amazon Kindle 8 Battery Replacement, Front Cover: 手順 1、 2の画像 2
      • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
      • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
      • Keep even pressure to avoid any cracks.
      • Lift front cover once all clips are disengaged.
      • Lift the front cover gently so that it is not cracked.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Kindle 8 Battery Replacement: 手順 2、 2の画像 1 Amazon Kindle 8 Battery Replacement: 手順 2、 2の画像 2
      • Insert the spudger between the inner front cover and the screen.
      • Gently work your way around to loosen the inner front cover.
      • Carefully lift the inner front cover from the device.
      FixBotに聞いてみる
      コメントを追加
    1. Amazon Kindle 8 Battery Replacement, Motherboard: 手順 3、 2の画像 1 Amazon Kindle 8 Battery Replacement, Motherboard: 手順 3、 2の画像 2
      • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Kindle 8 Battery Replacement: 手順 4、 2の画像 1 Amazon Kindle 8 Battery Replacement: 手順 4、 2の画像 2
      • Lift the screen and motherboard from the back cover.
      FixBotに聞いてみる
      コメントを追加
    1. Amazon Kindle 8 Battery Replacement, Battery: 手順 5、 1の画像 1
      • Pinch the clips on the battery and disconnect the battery connector from its socket.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Kindle 8 Battery Replacement: 手順 6、 1の画像 1
      • Insert the halberd spudger between the motherboard and battery.
      • Take care not to bend, twist, or puncture the battery.
      • Slowly move the spudger around the battery and pry it off.
      • The battery is glued in place, so don't be afraid to use some moderate force.
      FixBotに聞いてみる
      コメントを追加
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Luke
メンバー登録日: 09/25/24
456 ポイント
5のガイドは作成済み
チーム
University of Memphis, Team 1-5, Sneed Fall 2024 University of Memphis, Team 1-5, Sneed Fall 2024人のメンバー
UM-SNEED-F24S1G5
4 メンバー
13のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 72
過去 30 日: 315
今までの合計 6,113
