メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Fire Max 11 LCD Touch Screen Replacement
必要な工具と部品
    1. Amazon Fire Max 11 LCD Touch Screen Replacement, LCD Touch Screen: 手順 1、 1の画像 1
      • The heat gun can get very hot and can burn skin. If the device is heated for too long, it can be damaged.
      • Use a heat gun along the edges of the screen to loosen the adhesive.
      • Insert the iFixit opening tool along the seam between the screen and back case and gently pry around the perimeter of the screen.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Fire Max 11 LCD Touch Screen Replacement: 手順 2、 2の画像 1 Amazon Fire Max 11 LCD Touch Screen Replacement: 手順 2、 2の画像 2
      • Once the screen has been separated from the case, lift it slightly to reveal the display cable connected to the motherboard.
      • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
      • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
      • To reconnect:
      • Grip the cable and buckle together and insert the connector fully into its socket.
      • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
      • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
      • Remove the screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Anthony Martins
メンバー登録日: 03/18/24
522 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Konn Spring 2024 UMass Dartmouth, Team 1-3, Konn Spring 2024人のメンバー
UMASSD-KONN-S24S1G3
4 メンバー
4のガイドは作成済み
4件のガイドコメント
Okay, so I just replaced my screen and when powering back up the screen is black. I can hear the tone when it turns on or off, not sure which one because the screen is blank. Is the new lcd screen bad.
Carl Lee Fuller - 返信 共有
I went in and re-sat the ribbon and now I the lcd works but the touch screen does not work.
Followed the guide, got the screen replaced, everything works, good guide! A couple notes. My tablet had a piece of tape holding the wire in, I had to remove that, which is easy, but wasn't mentioned. Second, when you go to unplug the cable, the connector unclips from the opposite side to where the cable plugs in. So holding your tool at the edge of the screen go to the side of the connector closest to the edge and flip it up. Also, because someone else had a similar issue, I made sure the screen worked before I put the tablet back together which was good because I had an issue where the screen turned on but stayed black as well as the screen turned on but the touch part wasn't working. Reseating the cable worked. Third time was the charm. Power on open electronics at your own risk.
TLDR:
It is a VERY finicky cable.
Nicholas H - 返信 共有
Any Idea were I can source the frame of this tablet
Emily Cameron - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 93
今までの合計 2,557
