メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Amazon Echo Show 10 3rd Gen Tweeter Replacement
必要な工具と部品
    1. Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: 手順 1、 2の画像 1 Amazon Echo Show 10 3rd Gen Tweeter Replacement, Tweeter: 手順 1、 2の画像 2
      • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set it aside.
      FixBotに聞いてみる
      コメントを追加
    2. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 2、 1の画像 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      FixBotに聞いてみる
      コメントを追加
    3. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 3、 2の画像 1 Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 3、 2の画像 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      FixBotに聞いてみる
      コメントを追加
    4. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 4、 1の画像 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      FixBotに聞いてみる
      コメントを追加
    5. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 5、 2の画像 1 Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 5、 2の画像 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      FixBotに聞いてみる
      コメントを追加
    6. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 6、 2の画像 1 Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 6、 2の画像 2
      • Rotate the device to lay on its side with the tweeter's exterior facing you.
      • Unhook the 3-pin connector attaching the tweeter to the base with your fingers. Hold it as close to the base of the cord as possible, and lift it directly up from the socket.
      FixBotに聞いてみる
      コメントを追加
    7. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 7、 1の画像 1
      • Use a Phillips screwdriver to remove the four 10 mm screws attaching the tweeter to the main speaker base.
      FixBotに聞いてみる
      コメントを追加
    8. Amazon Echo Show 10 3rd Gen Tweeter Replacement: 手順 8、 1の画像 1
      • Remove the tweeter.
      • Repeat the previous steps if you are removing the other tweeter.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Macy Ormand
メンバー登録日: 09/13/23
1,101 ポイント
6のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Fall 2023 Western Carolina University, Team 1-4, Virtue Fall 2023人のメンバー
WCU-VIRTUE-F23S1G4
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 22
今までの合計 499
