メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Alienware Pro Wireless Gaming Mouse Battery Replacement
必要な工具と部品
    1. Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 手順 1、 3の画像 1 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 手順 1、 3の画像 2 Alienware Pro Wireless Gaming Mouse Battery Replacement, Feet: 手順 1、 3の画像 3
      • Flip the mouse over so the bottom is facing up..
      • Use an opening pick to gently peel the mouse foot off the bottom case.
      • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
      FixBotに聞いてみる
      コメントを追加
    2. Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 2、 2の画像 1 Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 2、 2の画像 2
      • Peel and remove the other mouse foot.
      FixBotに聞いてみる
      コメントを追加
    1. Alienware Pro Wireless Gaming Mouse Battery Replacement, Battery: 手順 3、 1の画像 1
      • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
      FixBotに聞いてみる
      コメントを追加
    2. Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 4、 3の画像 1 Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 4、 3の画像 2 Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 4、 3の画像 3
      • Use your hands or a spudger to separate the bottom and top of the mouse.
      • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
      • You may hear a cracking sound when the clips are released.
      FixBotに聞いてみる
      コメントを追加
    3. Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 5、 2の画像 1 Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 5、 2の画像 2
      • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
      FixBotに聞いてみる
      コメントを追加
    4. Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 6、 2の画像 1 Alienware Pro Wireless Gaming Mouse Battery Replacement: 手順 6、 2の画像 2
      • The battery is glued to the case.
      • Use an opening tool or spudger to loosen the adhesive under the battery.
      • Remove the battery.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Matt Seay
メンバー登録日: 09/29/25
401 ポイント
3のガイドは作成済み
チーム
Austin Community College, Team 10-3, Watkins Fall 2025 Austin Community College, Team 10-3, Watkins Fall 2025人のメンバー
AUSTINCC-WATKINS-F25S10G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 22
今までの合計 274
