メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1288/ 8, 16もしくは32 GB容量
2nd gen iPod Touch screen issues
I have an issue with my 2nd gen iPod Touch where it connects to itunes and is fully recognized, it holds charge according to itunes, but screen stays black, sometimes flashes
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did you try to reset it by holding the home button + sleep button ?
iPod Touch 2nd Generation Troubleshooting
さんによる 共有
probaby replace the screen, but it might something else
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
@codyweston a black screen that sometimes flashes has issues with either a loose connection, a completely failed display or a bad backlight circuit. Time to open it up and check to make sure the LCD cable is properly seated and undamaged. Check for any corrosion, debris, or bent pins. You can clean it with some +90% isopropyl alcohol and a soft brush, then reseat it. If that does not fix it, you will need to replace the LCD. Use this guide for that.
iPod Touch 第2世代のディスプレイの交換
Now, if even a new LCD will not work the issue will be on your logic board. There are no schematic for the iPod Touch. That means you will need to know how to do a boardlevel repair on that. Let us know what you find out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Cody Weston さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 35
過去 30 日: 35
今までの合計 35
