NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit ChiliTechnology ChiliCubeの分解 guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
(click on image)
このアンサーは役に立ちましたか?
Thanks for the info. I will let you know how i progress.
Fuse is good. So still looking.
過去 24時間: 2
過去 7 日: 7
過去 30 日: 35
今までの合計 136
