メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1998年11月発売。モデル番号はHKT-3020。
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
8 件のコメント
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
iFixitでの質問に画像を追加する方法
Thank you.
さんによる
Can I upload video? pictures won't help
さんによる
Yes you can!
Using Media
Thank you
さんによる
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
さんによる
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Alright. Then it is normal behaviour. Thanks for sharing!
さんによる
Sorry for the delay thank you
さんによる
No problem at all! Have a great day :)!
さんによる
コメントを追加
回答を追加する
Christopher D さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 183
