メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
realme Note 60 Androidスマートフォン(モデル:RMX3933)の修理、分解、およびトラブルシューティング情報。6.74インチ90 Hzディスプレイ、UNISOC T612プロセッサー、32 MPリアカメラ、5000 mAhバッテリーを搭載し、管理された条件下でIP64準拠の耐性を持っています。
How to fix it
my phone dropped into the water and got so many water inside and now the screen is not working its all black and not opening, turning on anymore
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
هاتفي يعلق دائما
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi @reynaldthe45058
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone anymore and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a teardown video of the phone that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Reynald Theo Leocadio II さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 52
今までの合計 247
