メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
250GB HDDと内蔵Wi-Fiを搭載した、クラシックなXbox 360の薄型モデルです。修理には複雑なこじ開け作業と専用のツールが必要です。
Random freezing, restarting by itself
My xbox is freezing during gameplay, mainly at the first loading screen I come across, rarely at the dashboard and I have to unplug the power cord to shut it off. Sometimes the wifi card isn't detected as well. I can play Rainbow Six Vegas 2 for 10 minutes before it abruptly shuts on and off by itself.
I've tried cleaning and repasting it, didn't work and I can confirm temps are low. I've also reinstalled the latest update.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Did you also tried to replace the HDD?
I would do that first and install the software again.
Guide: Xbox 360 S ハードドライブの交換
If it's still failing, try to replace the Wifi card and see if that solves anything.
Guide: Xbox 360 S Wi-Fi ボードの交換
I would try a new HDD first, you have some cheap ones at AliExpress and they do work fine.
Can you let us know how that goes?
Thanks!
Xbox 360 S ハードドライブの画像
ガイド
難易度:
とても簡単
1 - 5 minutes
Xbox 360 S Wi-Fi ボードの画像
ガイド
難易度:
中レベル
5 minutes
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I've tried removing the HDD before and it didn't do anything, I can run it without the wifi card and I still get the same issues so isn't that.
さんによる
If all the above didn’t worked, same for the HDD, then you most likely have motherboard issues. Most likely the internal memory on it.. I recommend to replace that. It won’t be easy as soldering is required. You can replace the motherboard but this will be expensive.
さんによる
@dan0 I have the Trinity model so was able to remove the 4gb internal memory, which fixed freezing during loading screens. The games now just freeze later on. The dashboard also wont respond to my input at times, but I'm able to open the smaller menu with the xbox button which does work.
さんによる
Okay! That’s a good thing!!
Please replace it for a new one and install it completely as new.
Does thet work?
Thanks!
さんによる
コメントを追加
回答を追加する
MangosteenJuice さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 160
