メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
FixHub パワーシリーズ|ポータブルパワーステーションとスマートはんだごてを組み合わせたポータブルはんだ付けステーションの修理とトラブルシューティング情報。2024年10月発売。
Touch-Safe indicator blinking blue.
My screen on my power station is not functioning, and I was able to still use my soldering iron using the touch-safe indicator for power on and heat up indication. During a recent job my soldering iron stopped heating up and started steady blinking blue.
Before the heat up blink was more of a slow pulse as it started turning orange. My firmware on both the power station and soldering iron is up to date and matching.
I could not find what the steady blue blink represents in any of the documentation. I'm still waiting for parts to become available to replace the screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi, @ofglamis I gotchu.
Good news! I think I know the cause to these problems.
The power bank needs a replacement screen, and iFixit sells a replacement display. The iron itself needs a new main board. I have the part links here and here, if you need a shortcut.
While wating for the new screen, you can use the web console. The guide included in the link will teach you how to do so.
Replace a damaged or malfunctioning display for your FixHub Power Station.の画像
製品
FixHub Power Station Replacement Display
$19.95
Replace a corroded or malfunctioning main board for your FixHub Soldering Iron.の画像
製品
FixHub Soldering Iron Replacement Main Board
$34.95
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for the input, I've been waiting for the screen to comeback into stock for the last few months. It looks like main board for the soldering iron is in the same boat. I guess I'll need to get a new travel soldering station until parts return to stock.
さんによる 共有
コメントを追加
回答を追加する
ofGlamis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 49
今までの合計 133
