メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第9世代Apple iPadの修理ガイド、分解情報、トラブルシューティングです。Wi-FiモデルとCellularモデルがあり、ストレージは64 GBまたは256 GBから選べます。2021年9月発売。モデル番号A2602、A2604、A2603、A2605で識別できます。
Where is the accelerometer
Hi all, I have an iPad 9th Gen (2021) where the rotation is not working. It does rotate but it is always 90 degrees out. So when you hold it in portrait the screen is rotated by 90 degrees as if in Landscape. I cannot find any info on where the accelerometer chip is, any help gratefully received.
I received this iPad as dead. It was a faulty NAND which I replaced with a new NAND after configuring the SYSCFG. It now works fine except for the rotation (please note this is after the restore and before activation (hello Screen), so no other apps loaded.
Thanks once again
Update (03/19/26)
Location of Gyroscope IC (accelerometer)
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There is a chip which holds the two sensors. But before you start digging in again let's double check things as there is also a gyroscope involved here as well. Go to the Apps Store and download this App Sensor Logger here's a snapshot of what it offers
画像
This is from my iPad M3 Air
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Thank you for taking the time Dan to respond. I cannot load any apps as this is a customer machine and after being restored it is iCLoud locked so I only the customer can activate it.
After further investigation I have also discovered the WiFi is not finding any local SSID's. However, the CHIP is seen and read by 3U Tools. So I think there is larger things wrong with this motherboard. Perhaps at the RF level.
For anyone wanting to know, I discovered the the acceleromoter + gyroscope is located in the IC located on the screenshot. It is the same part for all iphones 8 to 11. I replaced this IC and it made no difference.
So I am no nearer to finding the fault with the rotation and WiFi and have to give it back as a failed repair as it is not a viable repair. Thanks though I will bear this app in mind for next time.
さんによる 共有
@nathanjohn - Curious what else was wrong with it from the start? Did it have any physical damage. That's a bit much within different areas.
さんによる 共有
The original fault was that it was dead. It was not physically damaged and looked in very good condition. I could see from the power draw that it was looping on boot with no display. So I attempted an UPDATE of the IOS which failed at 19%, when the NAND is first written to. So I replaced the NAND, restoring SYSCFG and then IOS successfully. At this point the rotation issue was seen and later I saw that no Wifi was found. I also tried a couple more restores just to be sure. I then replaced the gyroscope IC and barometer sensor next to it. They are very close to the NAND and I really thought that perhaps a little too much heat had damaged them. Not the case, and the WIFI IC is at the other end of the board..... so very weird but you can't win them all.
I actually had two iPAD 2021's on the bench with the same fault. The other one was a successful repair.
さんによる 共有
コメントを追加
回答を追加する
Nathan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 25
今までの合計 260
