メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2023年10月に発売されたGoogleのスマートフォン「Pixel 8 Pro」の修理・分解情報。型番はG1MNW(NA/AU)、GC3VE(EU、インド)、GE9DP(JP)です。
Battery Replacement Calibration Issues
I got the new battery installed and drained it all the way down
Does go to 100% but I have to restart it to get the percent to change and when it does it says around 71% or 80% until it dies.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Anthony,
Where did you purchase the battery from? If it wasn't an OEM part or made by a reputible manufacturer, it may be lacking some of the necessary sensors for determining percentages properly.
However, there is a quick fix that may work that you can try:
  1. Charge your battery for a long period (overnight) so that it fully charges and then some. Ideally, do this when the phone is turned off.
  2. Turn the phone on and use your device until the battery is completely drained and shuts off on its own (I would reccommend turning the screen off time to never and running a very long video with sound to speed this process up)
  3. Plug your phone back into the charger and charge your battery to 100%. It is very important not to interuppt the charging process, so I'd probably leave the phone unattende overnight.
If this does not calibrate the battery properly, unfrotunately, the best option is probably to purchase a new battery. You can get an OEM battery from Google on the iFixit shop website: Google Pixel 8 Pro Battery - Genuine
Replace a dead or damaged model GUKD8 battery for a Google Pixel 8 Pro smartphone.の画像
製品
$52.99
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Bought from ifixit
I will try that again
Thanks
さんによる
Ok, great. If you purchased this from iFixit, I would suggest that you contact their customer service. If the battery does not work, they should probably give you a replacement/refund
さんによる
Drained it until it turned off
Put it on the charger for I want to say 12 hours
charged to 45%
plugged it back in after that and charged to 100%
that was this morrning, had it off the charger from 8am to 2pm it is telling me it is at 98% right now. It is acting like it does not want to update the percent.
さんによる
コメントを追加
回答を追加する
Anthony P さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 39
今までの合計 334
