メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Stange power problem between swapping outlets
When swapping outlets, the Xbox needs time with power to turn on. Instantly on and off until it decides to fully turn on typically 5-15 minutes.
Its the first one or two times then never have the problem until I swap plugs again. This is how I received the console.
Its any outlet, and a new Xbox powercord
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
I’m afraid it’s related to the power supply…
I would test it with a new one and see how that goes.
It’s probably the power supply causing this.
Guide: Xbox One Sの電源ブロック交換
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Strange thats my only symptom. I was leaning towards the battery that saves bios/etc.
The power button makes sound
On then off unless it sits plugged in
After initial turn on, never happens again
No safe boot but responds
Controller turns xbox on then off.
0 problems during playing
さんによる
Hmm, can you check the power settings?? You have “quick boot” and this will instantly turn it on. But when you selected the most power saving option, it will turn it fully off and turning it on again, will take time… When you swap from outlets it will completely turn off, so it will take time before it boots again. Long boot times could be caused by the HDD. Since you don’t have problems while playing games or when you just leave it in the wall outlet, it could be this… sorry
さんによる
コメントを追加
回答を追加する
zdog 033 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 164
