Charging USB is broken
この質問は役に立ちましたか?
Hi!
If it’s broken inside (like pins that are bent), you need to replace the port.
Replacing this one is NOT easy. You need to solder and need soldering skills to get it fixed!
Guide: PS3 Dual Shock 3 充電ポートの交換
Please let us know how it goes!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 370
1件のコメント
Could you disassemble it and check if there is continuity with a multimeter? Maybe it's just a solder joint that broke
dinoo_fixit さんによる
