メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年4月に発表・発売された第2世代iPhone SEの修理および分解情報。
Battery dies super quick
It dies so quickly
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Could you elaborate more? As far as I can tell you just need to replace the battery
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Oh no the battery compadity is literally 79 %
さんによる 共有
@thecat847 Yeah that is way too low. At 85 you should replace it
さんによる 共有
It works but I do have a toolbox to take out screws but no way to soften the glue and no replacement battery
さんによる 共有
コメントを追加
Go into your Settings under the battery heading will be the battery health. It's a percentage from 0-100 showing what the current capacity of the battery is vs. how much it should be able to hold. If it's less than about 85%, Apple says it should be replaced.
Over time batteries lose the ability to hold a full charge, so even though it says it's charged to 100%, it may only be holding 2/3rds as much charge as it should, meaning it's going to die in a much shorter time than it used to.
The solution here is to replace the battery. iFixit has a guide showing you step by step how to do that yourself. Note that unless you buy a genuine Apple battery (and have iOS 18 or later), you'll lose the ability to view the battery health information and get a pop-up warning for a week or so that the phone cannot determine if the battery is a genuine apple part. Other than those issues, an aftermarket battery will charge and work normally.
iPhone SE 2020 Battery Replacement - iFixit Repair Guide
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
The cat15 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 207
