メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年10月13日に発表され、10月23日に発売されたAppleのフラッグシップスマートフォン。6.1インチのOLEDディスプレイ、LiDARを搭載したトリプルレンズリアカメラシステム、5G通信に対応しています。iPhone 11 Proの後継機です。
Reattach/replace lightning connector?
Connecting lightning cable doesn’t always charge. It feels like something is loose in there. And when it doesn’t connect, a good smack of the phone downwards into my palm can do the trick. Also, the lightning cable can just kind of slip out, like it’s not catching in the receptacle.
So, what do you think is going on?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Given that the lightning connector is the hardest working part of the phone, generally being plugged and unplugged at least once a day if not more, it stands to reason if anything is going to wear out, it's going to be that plug.
Based on your description, it really sounds like your port has seen better days and should be replaced. I'm assuming here that you've tried all of the non-surgical remedies such as trying a different cable and cleaning and inspecting the port for any damage or obstructions like lint or dirt build up inside.
Unfortunately, iFixit doesn't have a guide to that repair, but the Spanish site Nadie Me Llama Gallina has just what you need. As you might guess, the site is in Spanish but does have an English language option.
Manuales / Apple iPhone 12 Pro / Load flex - Nadie Me Llama Gallina
I would definitely recommend replacing the port, which should get you fixed right up. If you want to support iFixit's repair efforts, you can purchase the part you need right here on this site.
iPhone 12/12 Pro Lightning Connector Assembly
If you're a bit more cost conscious, you can also find it on the major retailer sites like eBay, Amazon and AliExpress, plus a host of other places that specialize in phone parts.
Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627.の画像
製品
$26.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
kara07 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 44
今までの合計 674
