メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
How to get a new trackpad?
The trackpad gets harder and harder to use. It needs an unsual pressure to work. What can be done to fix it? Do I have to change the whole upper case? Do you carry them?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Your trackpad may just have a loose set screw that needs adjustment. Here's a guide that may get you to it: MacBook Unibody Model A1342のトラックパッドの交換
このアンサーは役に立ちましたか?
スコア 4
4 件のコメント:
I was hopeful looking at that guide, that I could get my trackpad out to soak alcohol after milk was spilled on it. But I have the 17" model, and the ribbon cable for the trackpad is so securely glued to the top case that felt I would ruin it trying to get it off. Very disappointing that I'll probably have to buy the entire top case to fix this. But looking at the picture of the part (which is out of stock), it looks like no trackpad is included?? MacBook Pro 17" Unibody (Mid 2010) Upper Case
さんによる
Let me get this straight, you are going buy a whole upper case rather than replacing a cable that can be ripped out and replaced?
さんによる
Open it up and see if the battery is swollen and pressing against the bottom of the trackpad.
さんによる
Actually I will probably just replace the trackpad. I could not find the part here, but found it on powerbook medic.
The battery is fine, recently replaced. The trackpad had milk spilled on it.
さんによる
コメントを追加
If you're willing to be a little unorthodox, you can try placing a thick napkin on the trackpad, closing the clamshell, turning the machine over, taking off the bottom cover, removing the battery, and then add gently pour a little alcohol onto the underside of the trackpad near where the sensitivity screw is, toward the "front" of the case (closest to where the user would be sitting). Be careful not to get the humidity sensor wet (small white dot if it hasn't been triggered... maybe red/pink/yellow if it has been triggered). The napkin absorbs the excess alcohol as it filters through the trackpad. If it was just a small spill that caused the issue, the alcohol will clear out any goo, and the click function will work again. This worked for me with two computers.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Weird. This is attributed to me, but I didn't write it. Bug in the system?
さんによる
コメントを追加
You will have to replace the whole upper case which can be purchased here.
Replace an upper case and backlit keyboard compatible with the Early 2011 model A1297 MacBook Pro 17 inch Unibody laptop.の画像
製品
MacBook Pro 17" Unibody (Early 2011) Upper Case
$64.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eric Dudan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 5,835
