メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleの13インチMacBook Pro Retinaディスプレイモデル(A1502)は、第5世代のIntel Core i5およびi7プロセッサを搭載し、感圧タッチトラックパッドが導入されました。
Trackpad problems! After replacing battery.
Guys, I have the same problem. The jack is ruined because of learning by doing... I accept the mistake, but isn´t there a way to just change the controller instead of extracting my new glued in battery again to replace the trackpad that is probably working? thx for helping me out in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@sebastians41717 - Please make sure you have the same model as the different models often have different issues. Post a picture or two that we can see any damage.
Also, how about telling us a bit more, does the trackpad have any reaction? Did you have problems in following the guide?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
On the guide (Step 18) MacBook Pro 13インチ Retina Display Early 2015 のバッテリーの交換 the cable is somewhat fragile and if bent to much when peeling it off from the battery it may cause an issue with the traces inside, it may be worth checking this step again to ensure it is firmly connected and possibly by replacing this cable, I have had one go down on me when installing a new battery. Hope this can resolve the issue. Be sure to get the 2015 version of the cable as I believe previous editions were different.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks alot!The Cable is fine but the ZIF Dock is broken. I think I produced a short cut when I placed the battery cable on the motherboard and THEN I connected the cable... I think the procedure is to take off the battery again and change the trackpad incl. the controller board.
さんによる
コメントを追加
回答を追加する
Sebastian Spiewok さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 91
