メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年9月22日に発売されたiPhone 8の修理情報およびガイド。モデル:A1863、A1905
iPhone 8 not recognizing Charge. Suggestions?
Hi I am hoping this gets some attention before I send my phone away, im pretty sure i know whats broken but just want to check to see if there's anything else I could check first.
I was working on my iPhone 8 as it needed a new Battery as I was working on it I accidently broke the ribbon connector for the Taptic Engine, I finished installing the battery while i waited for a replacement engine and the phone worked fine. However While i was Taking it apart to replace the Taptic i forget to disconnect the battery in my haste and now the phone will not show battery Percentage or seemingly charge, it will eventually show a percentage after sitting on a wireless charger for a while but in that time it randomly turns on and off. all i have found googling is that I must have damaged the MOSFET's, they dont look damaged but they could be.
Sorry for the long Question hopefully it makes sense.
Does anyone else have suggestions on what else it could be before i send it away?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
コメントを追加
1 件の回答
I'd recommend changing out the entire charging port flex cable.
You can find the part with or without the exact toolkit you need
HERE
iPhone 8の充電ポートのフレックスケーブルの交換
Replace a lightning connector assembly compatible with the iPhone 8. Includes the flex cable, logic board connector, lightning connector socket, and two microphones. Part #821-01163.の画像
製品
iPhone 8 Lightning Connector Assembly
$49.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
que que さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 192
