メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Speak & Spell 知育玩具の修理情報。1978年に初登場。
Touch keys not responding
First key on each row is not responding. Others work great.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
grammyjuju, take a look at the keyboard to make sure the contacts are all nice and clean. Check the keyboard connector on the logic board, make sure that the contacts are clean, not bend and that it is properly inserted. You can clean the contacts with an eraser. Check on here for some more diagrams.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Where can replacement membrane keypad assemblies be obtained?
さんによる 共有
コメントを追加
I have the 2019 Kahootz remake, and my keypad also started acting up. The wrong letters would be triggered on some keys, for example. I stuck a screwdriver under the top edge and used a plastic card around the edge to lift up the keypad. It is stuck to the plastic case with a light adhesive. I reseated the keypad and the problem went away. (I had first tried opening the case and cleaning the contacts from the keypad connector and tightening the 3 screws that hold it in place but that didn't help.)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I managed to remove the keyboard, however I seem to have the A-D not working properly. Any tips as to how I may solve this? Supplier told me to change batteries and try the reset button but none worked.
さんによる 共有
コメントを追加
回答を追加する
grammyjuju さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 45
今までの合計 3,372
