メインコンテンツにスキップ
Discover repair information including guides and tips for Whirlpool Refrigerators. Our comprehensive resources offer detailed instructions for troubleshooting and fixing common issues in various Whirlpool refrigerator models.
Is my freezer temperature too unstable
I bought a new Whirlpool side by side refrigerator freezer. I noticed quickly that ice cream was soft and I put a thermometer data logger in the freezer and found the temp was cycling between about +5 and 25 F and averaging about 13 F (measured with door closed continually over ~ 20 hours). After about 5 visits from the Whirlpool refrigerator technician they concluded it was unrepairable and replaced it with a new unit. However the freezer on the new unit also seems to fluctuate a lot in temperature. I don't store a lot of food in the freezer, and the new unit cycles between -3 and +20 F every 90 minutes and averages about 10 F. I filled the freezer with pans of water to test it under "full" conditions. This helped somewhat, but it still cycles from about -4 to +12 F every 90 minutes and averages about 3.7 F. I called it in under warranty again and the technician's initial response was "they are all like this nowadays," which I did not accept and he is attempting further "repairs" My question - is this safe and acceptable performance for a freezer (especially a brand new one)? What is a reasonable average safe temp range and fluctuation with door closed for a properly functioning freezer?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @scottkoefod
What is the model number of the refrigerator?
さんによる
@jayeff, it is WRS312SNHM08
さんによる
コメントを追加
2件の回答
最も参考になった回答
@scottkoefod
What's the temp in the refrigerator compartment doing e.g. is it going from approx 37°F to 50°+F every 90 minutes or is it not changing that much?
Did the service techs change any parts at all when trying to fix it?
If it is only the freezer compartment, were the freezer door seals and door alignment (i.e. straight and parallel to the cabinet) checked to make sure that no cold air was escaping from the compartment?
If not, to test this, place a sheet of paper between the freezer door and the door jamb and with the door closed normally i.e. no pressure on it by you to keep it closed, try pulling the paper out. It will come out with a bit of an effort but not that easily and it should definitely not fall out by itself. Do this at various places around the door, top bottom and both sides.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
@jayeff looking at the regularity of time and temp, I wonder if this could be an issue with some Auto defrost setting/part?
さんによる
@oldturkey03
I wondered about this also but looking at the parts list it seems that they either used the freezer temp sensor (aka evaporator sensor) for both functions i.e. freezer temperature control and auto defrost "control" i.e. signals when to turn off the defrost heater and end the defrost cycle or it's a fully timed event by the control board i.e. set timed period, when to start and when to stop auto defrost.
Could be that the board measures accumulated compressor run time (it controls when the compressor is turned on and off) so it could work out for how long it ran each time before the auto defrost had to happen.
Usually the defrost cycle start time could vary from every 8 hours to over 24 hours depending on ambient temps and user activity. Older refrigerators did this with the defrost timer but this model hasn't got one so it must be controlled by the board.
If the auto defrost cycle was based on a set compressor run time period then it should happen once every 8-10 hours as most of this type are and not every 90 minutes
I assumed that the service techs would have run the diagnostics (I can't find them online) to make sure that all the functions were as they should be, so presumably the sensors and the control board all tested OK
Cheers
さんによる
Thank you for the feedback. On both of the new Whirlpool units, the refrigerator temp was fine - it stayed consistently in the mid 30s - not a lot of fluctuation. On the first new freezer, the tech started noted "the system was restricted at the filter drier. Installed new dye drier, flushed the system with nitrogen, pulled a vaccum and charged to factory specs." This did not change anything. On the next visit the tech noted "Pressures took a long time to equalize which indicates the system is still restricted. No signs of leaks anywhere. We need to cut out the evaporator, blow through the cap tube, and install a new evaporator." Next visit they noted "cut out the evaporator, flushed with nitrogen, and installed a new evaporator. All pressures good after charging and we are getting a full frost pattern." This also did not change anything (freezer temp still never got to 0 and fluctuated just like in the graph above). Comments continued below. . .
さんによる
On the next service call, the tech noted "Low side running in a vacuum and pressure equalized at 6 psi. Charged with nitrogen to check for leaks and looked for dye. No signs of leaks externally." At this point they concluded it was un-repairable and replaced it with the second new unit on which I measured the graph above. I tried the paper test and the door seals seem to be good all around.
さんによる
@scottkoefod
Looking at the product sheet for the model series, it shows that it has 'adaptive defrost" which means that the defrost occurs when needed, based on compressor run time and number of door openings. Presumably both are related to how often the compressor has to run for (and for how long) as well as the number of times the doors are opened over a known time frame.
The temperatures you measured do behave as though the defrost cycle is occurring, but I don't think that it should happen that often, especially if it also happens overnight as presumably there's not much door activity happening.
All I can think of is that it might be a control board problem perhaps (firmware??) or a faulty door switch (can you prove that the light in the freezer compartment does turn off when the doors are shut by manually operating the door switch when the door is open?) as these are th etwo components that can affect the defrost cycle.
The other interesting thing is that the parts list doesn't mention a tech sheet, which is highly unusual in a Whirlpool parts list as nearly all do, Whirlpool doesn't provide them either so unfortunately without it I don't know how to run the diagnostics to check what may be wrong.
さんによる
3件以上のコメントを表示
コメントを追加
That does sound frustrating, especially after getting a replacement and still seeing the same issue. I’ve always heard that a freezer should ideally stay at or below 0°F for food safety, with minimal fluctuations. While some variation is normal, cycling up to 12-20°F seems excessive, especially for ice cream to stay firm.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Scott Koefod さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 74
今までの合計 74
