Trigger assembly issue . Not fixing
Ribbon between rubber strip and plastic tool got removed mistakenly while opening controller
iFixit does have a guide for replacing the trigger buttons, along with a guide for removing the wiring for the buttons. If the ribbon cable for the trigger button was damaged/severed, then it will need to be replaced.
ガイド
難易度:
中レベル
15 - 45 minutes
ガイド
難易度:
中レベル
30 - 45 minutes
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 9
過去 30 日: 21
今までの合計 378
5 件のコメント
Hey there, can you elaborate on the issue that you are having with your controller? Also some pictures could help us better give you advice. iFixitでの質問に画像を追加する方法
Jacob Mehnert さんによる 共有
can you send a picture?
Grant さんによる 共有
When I was opening my PS3 controller, mistakenly the left side trigger along with rubber strip and plastic tool beneath ribbon got removed. I am not able to attach them
Divyarth Singh さんによる 共有
Unable to send pics due to complicated process. Can you send a video or online video guidance if possible
@divyarthsingh im sure there are plenty of you tube videos on how to disassemble a PS controller you can find. but without pictures of your device we wont be able to help you really.
Logixal さんによる 共有
