メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
replace lcd zif/fpc connector
I need to replace a damaged ZIF/FPC connector for a Steam Deck. I cannot seem to find these anywhere. Is this a connector possibly used for another tablet/laptop?
Thank you for any help
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
Who manufactures this specific ZIF/FPC connector and where can it be purchased?
Thank you any help
さんによる
コメントを追加
2件の回答
ZIF connectors are fairly widespread, and it is possible to replace them - see the answer here and this YT tutorial. Though, it is not easy, a quick fix (if the pins are still working) might be insulating tape to keep the cable in place
このアンサーは役に立ちましたか?
スコア 0
7 件のコメント:
I am capable of replacing the connector, this connector appears to be specific to the Steam deck. Many are similar...just not the same. Be it pin number, direction of lock and so on. The Surface unit does not look the same.
さんによる
@tony28469 Could you post a photo of the cable that goes into this connector? Especially of any identifying mark/specification that may be printed on it. Maybe it is possible to find something compatible (even if it is not exactly the same)
さんによる
@tony28469 Or, if you're sure you can resolder it if needed, could you disassemble the connector to check if there is any part number/identifier on it? Worst case it can be helpful to work out something compatible by checking measures
さんによる
Hello,
There is only one logo/image on the clip that is GOL dead center and the #4 to the far right. This has lead to it being GOLD pins and nothing more. This connector has 26 pins on the front and 23 on the back and all sites that have connectors don’t list anything to match. I thank you for your help. I think this is a custom for Steam Decks.
Tony
さんによる
@tony28469 So also the ribbon cable has different numbers of pins on front and back?
さんによる
2件以上のコメントを表示
コメントを追加
Did you fix the problem? because I have the same problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tony さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 49
今までの合計 625
