メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストレージは128GBもしくは256GB
No Power, Not Charging
My Macbook Air A1369 wont power on. My battery died already, so whenever I want to use it, I need the AC power connected. Then this morning when I tried using it, the magsafe indicator light wont turn on. tried using another 45W magsafe adaptor and still wont work. I used both magsafe adaptors on another Macbook Air and they both work. Does anyone know why my Macbook wont turn on?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I have similiar problem. But My macbook have strange issue from one day to a another. I have something like taht my battery is charging. My macbook sees battery is charged but after when i unplug magsafe power cord it just turn off like he dont have power. I ordered new i/o board cable for th eon switch. And i gonna see what gonna be. But I'm !#^&@@ because i need laptop for my work and now i cant use battery
さんによる
コメントを追加
8件の回答
ベストアンサー
I would replaced the DC-In board first. There are five different units in the A1369 line, to get you to the correct part and installation guide we need the last three figures of your serial number: http://everymac.com/ultimate-mac-lookup/...
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Serial Number starts with C02F****DDR3
さんによる
Apple MacBook Air "Core 2 Duo" 1.86 13" (Late '10) Specs
Identifiers: Late 2010 - MC503LL/A* - MacBookAir3,2 - A1369 - 2392
さんによる
Here's how to replace the I/O board with DC-IN port, and a video on doing it: MacBook Air 13インチ Late 2010 I/Oボードの交換
さんによる
It's Apple part #661-5792. iFixit does carry this part: http://www.ifixit.com/MacBook-Parts/MacB...
さんによる
sir is there a way to test if it is just my I/O Board thats busted?
coz i wouldnt want to replace my I/O Board only to find out that there is more to replace.
Im better off buying a new mac air.
さんによる
2件以上のコメントを表示
コメントを追加
you can do first is SMC reset by pressing and holding 4 buttons on the keyboard to reset all the system hardware . press and hold ( Left Shift+option+command+ power button ) for approx 5 seconds then put the charger inside then check its charging or not . if still not light in the charger remove the charger . hold the power button and put the charger in after pressing and holding power button after 10 sec release the power up button and press it again . your system will boot up may be . if boot up donot remove the charger . use it for a while and check its charging or not . if not then restart it from the mac osx . if still not power up then your have to open it up for checking whats wrong inside .
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
tried it and the magsafe LED indicator still wont turn on, and unit still wont charge.
how can i tell if its the I/O board thats not working?
さんによる
yes you have to change the I/O board to work as normal
さんによる
コメントを追加
MacBook Air battery (inbuilt battery) dead plug to power adapter no light on the power adapter and I also did the SMC resset still yet no light on the power adapter
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I am having the same problem, did you find a solution for this?
さんによる
コメントを追加
My macbook air is not turning ON and the charger light is also not turning ON.
Please suggest solution.
I had done all sort of SMC resets etc.,
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had same issue with my macbook air. No boot and no charging. SMC reset didn't work. Unpluging charger and heating with dryer didn't work either. The solution was to open it up, unplug the battery from main board, wait half an hour and I could boot macbook. I noticed that battery was already 40% charged when it started up again, so macbook not being able to start was not due to low battery. It was due to some kind of crash or soft malfunction which entirely prevented macbook from booting until battery was unplugged from motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the same I removed the battery, waited 5 mins and plugged in the charger, came on orange light, plugged in battery was charging laptop worked without power adaptor in, but NO green light on chrger when plugged in but showed charging on screen. Initially green light came on but then changes to orange
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Charge your laptop full, charger light should go green, then try to power on the laptop, it will work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Clean where the plug goes! I had tried everything suggested,, this was only thing that worked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kit Gonzalez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 37
今までの合計 76,900
