メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第2世代Apple Silicon(M2チップ)搭載、13.3インチRetinaディスプレイ搭載のMacbook Pro 13インチ用の修理ガイドと説明書です。モデルA2338です。2022年7月15日、WWDC2022でMacbook Air M2とともに初公開。
BMU battery data cable connector broken
Hi there! I opened my laptop after I spilled a tiny amount of liquid in it… all good until I put everything back. Right at the end, by mistake, I pulled the cable from the BMU unit. One of the pins in the connector fell off. What are my options now? Please help …
画像
画像
画像
画像
Thank you…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Is this just the cable that has broken? If so you can find them on numerous sites for example on iFixit. If it is the actual connector on the logic board then you'll have to source a new connector from somewhere or someone who has a donor unit, and then find a specialist to remove / solder on the replacement..... This may prove to be a little hard to find.....Good luck!
Replace the small flex cable that connects the battery daughter board to the logic board.の画像
製品
MacBook Pro 13" Retina (A1708, A2159, A2338) Battery Daughter Board Cable
$16.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It’s the connector on the BMU. Thank you
さんによる
さんによる
コメントを追加
Yes the top part of the logic board connector (battery side) got pulled off. If you still have the piece you might be able to glue it back. But you will need to be very precise with the glue’s placement as it mustn’t interfere with the contacts or the latch. Replacing the connector is possible but it will take a hot air rework station and some skills to do it without making a bigger mess. Or, you just bite the bullet and replace the battery as the connector is on the battery side.
Either way I would remove the battery following this guide MacBook Pro 13インチ 2022 (M2) バッテリー の交換 as the person with the needed tool and skills only needs the battery and the needed connector BMU Cable Connector it’s also available from other sources. Or just replace the battery the guide offers the part info.
A better view on the connector
画像
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@danj I think you have confused yourself? The part you say is broken is on the logic board, you then say to replace the battery? This all makes no sense to me.....
さんによる
@livfe - yes it’s on a circuit board which is part of the battery. I’ve added a better image to my answer so you can see.
さんによる
@danj Ahhh OK better now, cheaper & easier solution!
さんによる
コメントを追加
回答を追加する
Alexandru Gorgos さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 27
今までの合計 1,073
