Sending and receiving a fax
I need to know how to find out what the number is for my fax for that I am able to send a fax and then the person I send the fax to is able to send one back.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
taylor parker, the fax number is the same as the phone number for the jack that it is plugged into. If your printer has a phone jack connector for a telephone, plug it in and call someone, like your own cellphone. Your number will show up. That will be the number for your fax. If you are using your fax from home, it will be your home number:-)
このアンサーは役に立ちましたか?
It may not be the most elegant way to find out, but you could send a fax to someone and have them tell you what number it is coming from.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 20
今までの合計 1,929
