メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PSP E1000は、ソニーが設計した携帯ゲームコンソールです。PSP Streetとも呼ばれるこのPlayStation Portableの廉価版は、2011年10月に発売されました。
Is my device bricked?
So, I was opening my PSP Street wide to get something stuck in the SD slot out, and I unplugged the LCD: And when I put it back the video output was fine at first but after some on/off it showed a white screen. I tried unplugging it and plugging it back and turns out I plugged it in loosely. However after a very short duration the screen gradually turned white, so I plugged it out.
Next thing I know the PSP has turned off and not only the battery stopped working altogether, but the display didn't show anything anymore.
Is it bricked? or can I somehow, by a miracle, fix it?
EDIT: Turns out the battery is fine, I somehow managed to plug it in in a way that it unplugs itself when I put the lid back on and pick the device up. 🤦‍♂️
Anyways, the screen remains an issue. I can see it changing brightness very slightly when I turn on the PSP, and nothing on the display itself seems damaged; But it shows a completely black screen. I've tried to shine a bright flashlight on it, but not much of a signal can be seen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Hi! White screens usually indicates that the cable isn’t connected properly or is damaged. Won’t your PSP not turning on anymore?? Or does it turn on at the moment?
Update (08/10/24)
Yeah, you probably need a new screen. The ribbon cable is probably damaged. I would try this first and see how it goes!
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
Turns out, the battery was just loosely plugged in. it can actually turn on without AC, but that still doesn't fix the screen issue. It's completely black, but it actually turns on and I can see it slightly changing brightness. I don't know if the display is fried or the device is bricked.
さんによる 共有
I probably can't get an exact replacement, what are the general specs I'm looking for?
さんによる 共有
Hi!
You need this one: https://www.aliexpress.com/i/10050052268...
They do ship worldwide!
さんによる 共有
@dan0 "This item is no longer available".
さんによる 共有
Then you need this one: https://www.googleadservices.com/pagead/...
The screen is expensive :(.
さんによる 共有
4件以上のコメントを表示
コメントを追加
回答を追加する
Zero さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 38
今までの合計 1,033
