メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Flipper Zeroは、センサー、レシーバー、その他の電子部品など、さまざまな電子ガジェットやシステムのハッキング、デバッグ、実験用に設計された多機能ツールデバイスです。
How can I fix water damaged flipper zero
Hello I accidentally left my flipper zero in my pants and it got in the washing machine now it won’t turn on and when I plug it in the charger it makes a weird noise . Do you have any tips on how to fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @kevinweber95396
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the device's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn it on and then remove the battery as soon as possible to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this, it might possibly work correctly again.
Here is the ifixit Flipper Zero repair guide that may help.
If this process seems too daunting, take your device to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Kevin Weber さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 32
今までの合計 672
