メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年10月に発売された14インチMacBook Proの修理ガイドおよび分解情報。Apple設計のM1 ProおよびM1 Max SoCを搭載。モデル番号A2442。
Ordering a replacement screen in Canada
I was curious about my ability to use the calibration tools when ordering a replacement display in an unsupported country?
I'm in Canada, and I have a US<>CAN shipping service I use frequently to order US items that don't directly ship to Canada. So getting the display should be no issue. But I wasn't sure if I would have problems using the tools to calibrate the display.
Has anyone in Canada used the tools? People mention running them through a VPN, but I just wanted to confirm if anyone's actually done that successfully.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Good question! I think you'll need to use a VPN which has a US IP address to make sure it goes as intended.
If you do try to get it to work with a Canadian IP and it works let us know! Otherwise its the VPN.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Just deciding whether it's worth the risk (as the screen is a really pricey part).
My only worry is that even with a VPN, i will still get shut down on account of the serial number being potentially visible to Apple as a Canadian device.
I'm just trying to read around a bit on what the worst case scenario is if the tool doesn't work. If it's only losing true tone than I'm mostly OK with that - but if there are issues with local dimming zones, then that will make the screen essentially useless to me.
さんによる
コメントを追加
回答を追加する
George K さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 31
今までの合計 368
