Surface pro screen flicker
Hi,my surface pro screen is flickering and goes blurry after about 10 minutes,it’s all updated and also done a fresh installation of windows 10 but still the same, can you please help
Hi @robbo1735,
Try connecting an external monitor to the laptop's mini DP port and check what happens to the display on it.
If it doesn't flicker then most likely the problem is with the screen in the laptop.
If it is determined that it is the screen, here's the ifixit Microsoft Surface 3 ディスプレイの交換 guide that may help. Take note that the repair is rated as difficult
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 419
