Can I get a replacement battery for this here at Ifixit?
I noticed that on the website that there is only the early 2015 Macbook Pro battery available. Is it compatible with my model macbook Pro?
I’m a bit confused, do you have a 13” or 15”?
Why I ask is the 2015” was introduced in Mid 2015. Either as a IG model - MacBookPro11,4 or a DG model - MacBookPro11,5
The only Early 2015 model is a 13” system MacBookPro12,1
To verify which is your system either look as the About This Mac or ir your system is not running then plug in your systems S/N into here EveryMac - Lookup
Once you know let us know! Or just click on the correct guide here which also offers the correct parts info
15” models MacBook Pro 15" Retina DisplayMid 2015のバッテリーの交換
13” models MacBook Pro 13インチ Retina Display Early 2015 のバッテリーの交換
ガイド
難易度:
難しい
45 minutes - 2 hours
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 43
