メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2021年2月に発売されたSamsungのAndroidスマートフォン、Galaxy A32 5Gの修理および分解情報です。
Screen is black always
What type of software (or is there any) would I need to fix black screen problem. Or do I need an LCD
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @mrmbellis
Has the phone been dropped or gotten wet at all?
With the phone turned on does it still give audible indications that calls/notification are there?
If so you could try shining a flashlight at an angle close to the screen and check if you can see any images at all. They will be very faint so trying in a darkened room may help to see them if they are there.
If they are there then this just signifies a backlight problem with the screen and doesn't help much unless when the screen is replaced that it also doesn't work either, due to a backlight problem on the systemboard and not in the screen itself.
Here's the ifixit Samsung Galaxy A32 5G スクリーンの交換 guide, that shows what to do.
Search online for GH82-25122A GH82-25121A to find LCD display suppliers that suit you best.
Note: If you click on the Galaxy A32 5G icon next to your question, in the page that opens there's a Troubleshooting guide located in the Documents section down the page and on p.23/50 of the document is the Main Display troubleshooting guide that may also help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Mr.M.B. Ellis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 44
今までの合計 700
