メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年12月に発売された第4世代 Mac Proの修理ガイドと解体情報です。
Ssd module adapter please help!
Does a Mac 2019 ssd module adapter exist? Any bypass of t2 chip?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Before we can answer we’ll need to know what you’re trying to accomplish. What are you trying to adapt to what?
さんによる 共有
Such a quick response! I have a Mac Pro 2019 which has the t2 chip. I had to have the logic board replaced and I have a Mac module ssd drive that was raided to another internal.
I only want to make a copy of what’s on the Mac Ssd module. But only know to connect it via the computer. Doing so will fry the existing data. This is what I’m trying to avoid.
I hope this makes sense. Thank you in advance to any insight anyone has.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Just not possible!
This series does not use a true SSD but instead uses a set of Flash modules there is no means to access the data from within them unless they are installed in the given system they came out of which offers the controller element (the data is striped across the modules) and the security key as the data held is also encrypted!
Last point you can’t alter which module sits in which bay either! A needs to sit in bay A and so on. B won’t work in bay A or any other combo this is due the the data striping and the first module is also slightly different as it hold the firmware bootloader.
Review Step 11 with in Mac Pro 2019の分解 and then jump to Step 8 within this iMac Proの分解 as it’s the same module.
iMac Proの画像
ガイド
iMac Proの分解
難易度:
中レベル
Mac Pro 2019の画像
ガイド
Mac Pro 2019の分解
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Nels さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 50
今までの合計 624
