メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Powerbeats Pro 完全ワイヤレスイヤホンの修理および分解情報。2019年5月発売。モデル番号:MV6Y2LL/A、MV702LL/A、A2047。
How do I replace worn out batteries
The powerbeats pro charge to 100% in the case and shut off after 30 minutes of use
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
5 件のコメント
I ordered a pair of Varta CP1254 A3 batteries advertised for Powerbeats on eBay but the 5.4mm height is about 1mm taller than the OEM battery. It doesn't fit. All the listing specs also have 5.4mm height? Any suggestions?
さんによる
@bloodygalah
Have you checked the original battery to see what model number is stamped on it?
さんによる
@jayeff
No markings on the OEM battery at all I'm afraid
さんによる
@bloodygalah
That makes it tough.
You may have to measure the dimensions and then see if you can find a similar size "3.7V 0.2W rechargeable battery with solder tabs".
Soldering wires to a battery is dangerous as it heats the battery too much. That's why getting batteries that already have them factory fitted is better and safer
さんによる
@bloodygalah
Apologies, must have had a brain fade.
Obviously not AA size.
Also since the original has no markings make sure that if you do find a replacement that you connect it correctly i.e. +ve side of battery to +ve wire from the board if wires are coloured then red wire is +ve and black wire is -ve.
You may need to have a DMM (digital multimeter) to find out which is the +ve side on the original battery if the connecting wires aren't coloured differently.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @harveyhimel
Here's the ifixit Powerbeats Proの分解 video that shows how to access the battery.
The battery make and model number is Varta CP1254 A3. Search online for Varta CP1254 A3 to find suppliers that suit you best.
Here's an image from the video that may help
画像
(click to enlarge)
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Harvey Himel さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 40
過去 30 日: 184
今までの合計 15,468
